How can I avoid small holes inside areas
  • Jan 16, 2024 11:51 AM UTC
  • 70 views
limo
Forum|alt.badge.img+8
Hi all,
after NDVI calculation I select pixel values within a certain range. Afterwards I use a clipper to obtain only the desired area. Based on pixel values I get the following result:
imageAfterwards I used "RasterExtentsCoercer" in combination with "Generalizer" to get smooth areas.
It would be nice if the very small holes (yellow example) are combined to the detected area. Only larger holes should remain! How can I do this?
 Thanks in advance
dustin
Forum|alt.badge.img+36
  • Jan 16, 2024 12:04 PM UTC
When looking to filter holes in areas, I normally use this method:
  1. Use a DonutHoleExtractor to seperate the holes from the outer shell.
  2. Send the holes to an AreaCalculator to get the size.
  3. Use a Tester or TestFilter to filter out the holes you want to keep based on the size.
  4. Use a DonutBuilder to recreate the original areas without the small donuts.
geomancer
Forum|alt.badge.img+71
  • Jan 16, 2024 12:35 PM UTC
See also this question.
limo
  • Jan 16, 2024 12:44 PM UTC
thanks @dustin this works for me fine :)
I can filter out smaller holes!
