How can FME search for variations in word casing?
  • Dec 27, 2017 12:09 PM UTC
  • 71 views
I have a work space that creates an error report for a dataset, that I would like to amend.
The current error report brings back the error "Area of Outstanding Natural Beauty (AONB)' fails check for case is 'FULL_TITLE", however this isn't an error as the of being lower case is to be expected. In FME, for strings like the above, how can I allow 'of' to be lower case and not be included in the error report please?
I think it might be require a regular expression of some sort, but not sure if \\bof\\b would do the trick.
Would really appreciate your help.
Thanks,
JB
erik_jan
Forum|alt.badge.img+26
  • Dec 27, 2017 2:21 PM UTC
The AttributeValidator has a check if one or more attributes match a specified case.
  • Dec 28, 2017 2:42 PM UTC
Thanks Erik.
I have given AttributeValidator a go, but still not sure how to ask it to allow 'of' when it is in the middle of a string such as Areas of Outstanding... In the rule configuration section, what would the regular expression be please?
Jess
erik_jan
  • Dec 28, 2017 3:01 PM UTC
In the case of this sting, I needed two StringReplacer transformers to validate the text.
The first replaces " of " by " Of ", which matches your question.
The second was needed to replace the text in parentheses using the regular expression "\\([A-Z]*\\).
