ho un dato vettoriale in cui per ogni entità ho diversi valori e devo prendere il dato con il valore massimo
  • Mar 13, 2023 10:54 AM UTC
  • 35 views
emiliodepalma
nielsgerrits
Forum|alt.badge.img+67
I have a vector data where for each entity I have different values and I have to take the data with the maximum value.
Multiple ways to do this, but the easiest is to use a Sorter on the attribute and a Sampler to select the first feature.
