Hi ! I would like to remove the "," at the very beginning of the concatenation.
  • Apr 1, 2022 5:37 PM UTC
  • 93 views
I tried with the transformer "substringextractor" but I remove the "1" from my thousandth when there is no comma at the beginning.
I saw that there was a transformer "LastSectionOfStringRemover", maybe it exists for the beginning?
Best answer by chrisatsafe
Hi @clozanolpz​ ,
You can use a StringReplacer in the Replace Regular Expression Mode with the following text to replace:
chrisatsafe
  • Apr 1, 2022 6:18 PM UTC
Hi @clozanolpz​ ,
  • Apr 2, 2022 11:44 PM UTC
Alternatively, you can also use the AttributeTrimmer to remove a specific character from the left side and/or right side of a string.
  • Apr 12, 2022 1:10 PM UTC
Hi Chrisatsafe and Takashi!
Both solutions work, thank you !
