Hi, I need to bring some correction to a CSV file. The picture on top shows the rows (highlighted) that need correction. The one in the bottom shows the row in corrected form. Would this be possible in FME workbench 2023.1? In my case several ti
  • Nov 28, 2023 6:34 PM UTC
  • 7 replies
  • 93 views
louisboekhoudt
correction neededcorrected
hkingsbury
Forum|alt.badge.img+73
  • Nov 28, 2023 7:14 PM UTC
It looks like you have erroneous new line characters in the input csv which is causing it to break over multiple lines.
Unfortunately its not quite as simple as removing all new line characters as that would break the csv even further.
Can you share the raw CSV file here?
louisboekhoudt
Note that the ";" character also need to be chenged to ",".
hkingsbury
  • Nov 28, 2023 8:15 PM UTC
I think you have a number of issues with the csv, probably the least of which is the line breaks.
The problematic line has 53 fields, but the header line (and other lines) has 50
You also have double quotes starting the line which in a csv will subsequently escape any commas. This means that row 4, is actually only parsed as one field
louisboekhoudt
I know, been busy looking for solution since monday. Hope you can bring me closer to one.
geomancer
Forum|alt.badge.img+71
  • Nov 29, 2023 9:29 AM UTC
Of course this is possible with FME 😉
Repair_CSV
Steps:
  • Read the whole file into one feature (Text File, read whole file at once)
  • Split on ""
  • In the odd-numbered features (which contain the data originally between "") replace ";" with ",", and CR/LF with a space
  • Restore the order of the features, and concatenate
  • Split on CR/LF, remove all "
  • Export to a Text File
The resulting CSV file is read correctly by Excel.
Note: This solution works on the data you provided, it may not work if there are other problems in your data. In that case it may be better to go back to your source and obtain a better CSV file.
louisboekhoudt
Percfect, It works Geomancer.
Thanks👍
geomancer
  • Nov 29, 2023 2:54 PM UTC
Thanks👍
Thanks for the feedback, glad to know it works!
