Hi, I'm trying to execute a query on AZURE Spatial database using SQL creator. and generate features. When I specify Reader options on SQL creator it doesn't give Azure Spatial as an option (only Azure non-spatial). Therefore it doesn't read the geo
  • Oct 5, 2020 4:25 AM UTC
  • 28 views
Hi, I'm trying to execute a query on AZURE Spatial database using SQL creator. and generate features. When I specify Reader options on SQL creator it doesn't give Azure Spatial as an option (only Azure non-spatial). Therefore it doesn't read the geometry
kailinatsafe
Forum|alt.badge.img+24
Hello @nisa​ , what version of FME are you currently working with? Have you tried using Microsoft Azure SQL Spatial Database (JDBC) in the SQLCreator?
