Hi, I'm new to FME software and community. I have a question. I have three 3D points that don't have same height. I want to create arc from these points.
  • Sep 1, 2022 12:16 PM UTC
  • 102 views
cuckovic_nikola
Participant
Forum|alt.badge.img+4
First, I have straight lines that are connected, then i extract end points and mid point (which I offset in direction of Z axis). From there I use these points to manually draw arc that connects these points. I want to know is there a possibility to automate this process. These lines are representation of wires between poles. I'm new to this software and don't have much of knowledge so any help would be appreciated.
  • Sep 1, 2022 12:42 PM UTC
Did you try the ArcEstimator? The result is 2D, however.
cuckovic_nikola
Participant
Hi, I have tried but as you wrote, the result is 2D but I need 3D result.
  • Sep 2, 2022 7:10 AM UTC
Actually, I just tested with a 3D polyline as input to the ArcEstimator, and the output is also 3D.
If you're still struggling, please post some sample input data here.
