Hi , I have a stacked point devices where more than 1 device in same location . I want to move those devices to 5 feet distance in the same line which exist .
  • Jun 21, 2023 5:25 AM UTC
  • 118 views
kokilam
Forum|alt.badge.img+9
I have tried using spread duplicate points remover followed by neighbour finder , but the feature is still in same location .
This is critical issue . can you please help on this ?
DanAtSafe
Forum|alt.badge.img+23
  • Jun 21, 2023 4:06 PM UTC
Hi @kokilam​ I'm not sure of what you mean by "in the same line which exist" but I'd try the Offsetter. You can calculate the offset in x & y with the Arithmetic Editor.
kokilam
  • Jun 27, 2023 4:40 AM UTC
Hi Dan ,
Thanks for the reply .
So in my case there is utility network . The Electric Devices will be on top of the Electric line .
Currently some devices are (more than 2 or 3 devices at same location ) . What I want is I want to the move the Device feature 5 feet from the original location .
the Logic which I used is I created the buffer of 5 feet of Device features and passed it to the Line on Area Overlayer ,from the output of Overlayer (Line feature ) , I extracted the coordinates of line feature and created the vertex (replace with point ) . But that logic is not working for some feature .
DanAtSafe
  • Jun 28, 2023 7:47 PM UTC
Hi Dan ,
Hi @kokilam​ How is it not working for some features? If the offset needs to be 5 feet along the line and there is a bend within 5 feet of the Electric Device then you will have to use measures (or a Snipper) to find that exact 5-foot offset.
