Hi, I have a CAD file with 1000 polygon, 500 out 1000 are shifted 0.2m. I want to keep only 500 regardless of the shifting. please advice. thanks
  • Nov 12, 2023 9:13 AM UTC
  • 18 replies
  • 139 views
ohashkii
Forum|alt.badge.img+8
Best answer by takashi
Thank Takashi,
No specific criteria. Only the user inserts two polygon cad layers from different sources on the same CAD layer with an error varies from 0.0 to 0.3 cm.
I think Matcher is still helpful.
Set an appropriate value (e.g. 0.5 or so) to the Vector Tolerance parameter, and take a look at output features from the SingleMatched port.
  • Nov 12, 2023 1:01 PM UTC
Hi @ohashki​ ,
​What is the criteria to determine if a polygon is shifted?
ctredinnick
Forum|alt.badge.img+22
  • Nov 13, 2023 12:30 AM UTC
Something like this:
imageconvert the polygons to points, so you can compare them with a point on point overlayer to find those which are offset from each other. Then, pick one from each set of overlaps, and return it back to a polygon.
ohashkii
  • Nov 13, 2023 7:11 AM UTC
Hi @ohashki​ ,
Thank Takashi,
  • Nov 13, 2023 7:43 AM UTC
Thank Takashi,
ChangeDetector might help you to compare polygons read from the two differenct sources.
ohashkii
  • Nov 13, 2023 7:51 AM UTC
Thank Takashi,
This case is an existing file. two sources are already merged into one file.
  • Nov 13, 2023 9:15 AM UTC
Thank Takashi,
OK, have a look at Matcher too.
ohashkii
  • Nov 13, 2023 9:41 AM UTC
Thanks... the logic looks fine. But I cant find the value of for the right value of the tester (@value(_min_count)) .
ohashkii
  • Nov 13, 2023 9:43 AM UTC
Thank Takashi,
Sir,
it seem that you misunderstand the problem.
Matcher gives you the identical features.
  • Nov 13, 2023 1:46 PM UTC
Thank Takashi,
Yes, that gives you identical features. The identical features are not-shifted features, aren't they?
ohashkii
  • Nov 13, 2023 5:15 PM UTC
Thank Takashi,
Please re read the question.
  • Nov 13, 2023 9:19 PM UTC
Thank Takashi,
Could you please elaborate what situation is "shifted" or not?
  • Nov 13, 2023 9:53 PM UTC
Thank Takashi,
See the attached screenshot.
I thought that the left situation is "shifted" (orange polygon doesn't match blue one), the right situation is "not-shifted" (orange polygon matches blue one).
If it was correct, you can detect "not-shifted" (matched) polygons with Matcher.
If not, what situation is "shifted"?
polygons
featuremichael
Forum|alt.badge.img+9
@ctredinnick​ @ohashki​ Good Morning from Austria,
Sorry to ask, but how can I guarantee that the lower counter ID is the correct geometry?
greetings Michael
ohashkii
  • Nov 14, 2023 7:32 AM UTC
Thank Takashi,
500 polygons are mistakenly inserted twice at CAD file(duplicated) with a shift of 0.2, They became 1000. I need to remove the duplicated ones (500). is that clear Sir.
ctredinnick
  • Nov 14, 2023 8:57 PM UTC
greetings Michael
I don't think it mattered which one was 'correct', just that only one was picked.
An even simpler setup is just to use a Matcher, checking geometry, with a 0.5 tolerance. If there is some criteria for picking which one of the duplicates to keep, then you can apply that on the features which come out as Matched. Else just keep the Single Matched and Not Matched features.
  • Nov 14, 2023 11:44 PM UTC
Thank Takashi,
featuremichael
My Bad, i didn't saw the answer in the question -.-'
ohashkii
  • Nov 15, 2023 1:32 PM UTC
Thank Takashi,
Thanks....
Now...You get it right.🙂
