Hi! How can i be sure the clippers arrive first if they are in same Reader as the clippee?
  • July 21, 2016
  • 134 views
Best answer by erik_jan
Use the FeatureHolder transformer in front of the Clippee port to hold all features entering that way until all Clippers are read into the Clipper transformer.
But the advantage of this approach in the Clipper might not exceed the disadvantage of holding the features in the FeatureHolder. You will need to do a performance test.
erik_jan
Forum|alt.badge.img+26
  • July 21, 2016
  • July 21, 2016
I agree completely. I think the better option would be to create a separate reader just for the clipper geometries, then make sure that reader is moved at the top of the navigator.
