Hi folks I'm searching informations for importation of donuts (archipelago) inside GDB format. Up to now, all my donuts are ejected when I try to integrate them. I can do the import in GDB open API or GDB with ESRI licence.
  • Sep 10, 2020 10:30 AM UTC
  • 45 views
caracadrian
Forum|alt.badge.img+23
  • Sep 11, 2020 5:21 PM UTC
I don't really understand your case. It can be polygons with holes or multiple polygons as one feature.
For polygons with holes/donuts you should verify if your features are donuts and if not just use the clipper/outside to create them.
​For multiple polygons as a single feature use the aggregator to build your archipelago.
In both cases, set your GDB writer as geodb_polygon.
Ok thanks a lot.
