Hi everyone, I am trying to set up a webhook in the Cityworks AMS, so it will send values of the Inspection to the FME Server. The goal is to use one of the AnswerValue to populate different field on the Inspection by the Inspection Update API.
  • May 29, 2023 8:02 PM UTC
  • 0 replies
  • 52 views
serg42932
The problem I am facing is I cannot figure out how I can send Answer value for Observation Question to the FME Server.
I have been using this syntax:
{"Address":"~~Location~~", "InspectionId":"~~InspectionId~~","Observation_Id":"~~ObservationId~~","Facility_Id":"~~Facility_Id~~","AnswerValue":"[~~AnswerValue~~]"}
Also, I can find API documentation for the InspectionAnswer, but I am having trouble setting the right Syntax, so it will send Answer Value to the FME Server. Can someone help, please?
Thank you
