Hi, does anyone know if there is a way to extract geometry from a feature as GeoJSON in an attribute (in general i'm using GeometryExtractor) but having access to the options that the writer gives? Specifically the file Structure options contained th
  • Jan 19, 2023 10:27 AM UTC
  • 106 views
adrian_farrell
We need this to be able to post the attribute to an API which requires one of the other File Structure types than the default
Best answer by david_r
Off the top of my head, there are two options:
  1. Use the JSONTemplater to generate the entire GeoJSON document, or
  2. Use the FeatureWriter to write the GeoJSON to disk, then read it back into an attribute, e.g. using an AttributeFileReader connected to the summary port, reading from the file referenced in the "_dataset" attribute.
Forum|alt.badge.img+54
  • Jan 19, 2023 10:45 AM UTC
I'm not sure I fully understand the ask, but could you write to geojson with a featurewriter with whatever settings you need, and then reread that file in as text to get the json you need for the API?
adrian_farrell
Thanks, I think this is a slight omission from the GeometryExtractor but this solution works great, especially with AttributeFileReader in the mix
