Hi all. I have a PostgIs table that has polygons and a attribute with a market name. I'd like to export all of the data into a GDB file using the market name as a different layer for each one. Is that possible? Any help would be appreciated.
  • Mar 4, 2021 11:57 PM UTC
  • 59 views
Bonus points if I can reproject them to UTM per layer! Thanks!
Forum|alt.badge.img+63
Yes, that's possible.
You can set the output table name to the value of the market name attribute in the writer feature type. That'll create a new table for each unique value for that attribute.
Reprojecting can be done by using a Reprojector or ESRIReprojector (or specifying source and target projections on the reader and writer respectively)
  • Mar 6, 2021 1:48 AM UTC
I thought I tries that and the writer wrote out multiple GDBs rather than a single GDB with muliple layers per market. I'll try again. Thanks for your answer.
tomf
Forum|alt.badge.img+31
  • Mar 7, 2021 11:54 PM UTC
You need to set the market name attribute at the Feature Type level, rather than at the Dataset level. A fanout at the Dataset level will create multiple fgdbs with one feature class, a fanout at the Feature Type level will create one fgdb with mutliple feature classes.
FTfanout
