Hi All. I have a Civil 3D file that has block data that contains several attributes. When I set the parameters to explode blocks to entities all the attribute information is lost. Is there anyway to preserve the attributes?
  • Oct 11, 2021 8:14 PM UTC
  • 80 views
If I do not explode, I loose the 3d surface and the geometry is shown as point.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @awais​, The AttributeKeeper might solve your problem. Place it in between the AttributeExploder and your Output and select the attributes you'd like to keep (name, geometry, etc). Hope this helped!
  • Oct 13, 2021 5:26 AM UTC
I am loosing the values inside the attributes. Attribute fields I can see after exploding.
