Hi all, I am fairly new to FME but have a problem with an httpcaller in a loop. I cannot seem to stop the translation when all records returned. Any help would be appreciated.
  • Sep 24, 2021 2:57 PM UTC
  • 6 replies
  • 229 views
I've got a HTTPCaller in a loop that retrieves data page by page (I use offset and limit). I have a tester that tests whether 'has_last_page' is true. This all seems to works ok but the translation does not stop - it just keeps repeating the last URL even though all records have been returned.
Best answer by nick824
Hi all, I tried cloner option and worked very well if I can get records per page etc. When the only data available is 'has_next_page' I eventually found that by moving the JSON extractor and JSON fragmenter stages out of the loop and placing them just before the writer it works like a treat.
  • Sep 24, 2021 3:33 PM UTC
Maybe the sample workspace posted by @bruceharold​ here can give you some clues: https://community.safe.com/s/question/0D54Q000080hPDg/resolving-pagination-with-httpcallerloop
  • Sep 24, 2021 3:44 PM UTC
ok thanks, I'll take a look
itsmatt
Forum|alt.badge.img+48
  • Sep 26, 2021 11:20 AM UTC
As an alternative, if you know how many records per page and how many total records there are you can use a cloner to​ create the required number of features and calculate their offset. This let's you avoid loops, however, if the total number of records isn't present then this isn't an option.
  • Sep 27, 2021 11:54 AM UTC
Thanks for the advice. Unfortunately I don't know the number of total records. I just have 'has_next_page' and 'total_rows'. I know that there are 25 rows/page but the 'total_rows' only reports a maximum of 501 so does not necessarily reflect actual.
  • Oct 14, 2021 7:00 AM UTC
itsmatt
  • Oct 14, 2021 7:11 AM UTC
Nice, good result!
