Hey community! I need to know if I can export in a python script language my total transfomation of my workflow. Can I do it? And how can I make it?
  • Dec 15, 2020 6:56 PM UTC
  • 5 replies
  • 60 views
giuseppecfgeo
Forum|alt.badge.img+5
hkingsbury
Forum|alt.badge.img+73
  • Dec 15, 2020 7:03 PM UTC
Hey, you can't convert an FME script to python.
You can add start/finish python scripts, call python scripts from the workbench (PythonCaller/PythonCreator, SystemCaller) and you can also use python to call a work bench (something like os.system())
When you run a workbench the first few lines of the Translation Log contain the command line parameters to run the job
Screenshot 2020-12-16 080321
giuseppecfgeo
  • Dec 15, 2020 7:14 PM UTC
So can I use the first few lines of the Translation Log to insert it in python and create a little app or not?
hkingsbury
  • Dec 15, 2020 7:30 PM UTC
Yes, but the machine you run in on will need to have FME installed and licensed. Why are you needing to call fme from python?
giuseppecfgeo
  • Dec 15, 2020 7:41 PM UTC
I just need to remake the same transformation in python​
hkingsbury
  • Dec 15, 2020 8:05 PM UTC
All that the first few lines are going to do is call FME to run the process. To recreate the logic in Python you're going to have to start from scratch. If you're dealing with any spatial operations your going o have to use libraries such as ArcPy (Requires Esri License) or GDAL
