Help with PointOnRasterValueExtractor : Getting band names
  • Jan 20, 2020 3:49 PM UTC
  • 95 views
yaze
Hello,
I am overlapping a set of points on a combined raster from 200 previous ones and then exposing obtained values as attributes. However I want to get the attribute names as FME_Basenames (fig 2) and not as shown in (fig 1). Is there somehow how to to do ? Thank you very much
(fig.1)
(fig.2)
jdh
Forum|alt.badge.img+41
  • Jan 20, 2020 4:05 PM UTC
You could probably use the RasterBandPropertExtractor to get a list of band names and then rename the attributes so that _band{n}.value becomes @Value(_band{n}.band_name).
However exposing the attributes so they are present on the canvas can't be done dynamically.
yaze
  • Jan 21, 2020 11:03 AM UTC
Tried to do that but couldn't figure exactly how to. Can you explain more ?
Forum|alt.badge.img+54
  • Jan 21, 2020 12:31 PM UTC
I'd resort to python for the renaming step (you could explode, create an attribute from the band name and set it to the band value and then re-aggregate)
