Hello everyone, I am working on spatial data. The graph shows multiple lines outside the desired area. I used generalizer but did not work. I discovered that spike removal works perfectly, but numerous remnants are left. How should I remove it?
  • Mar 16, 2023 9:38 PM UTC
  • 35 views
Here is an example: I want to remove the small dots inside that circle. Thank you. image
Forum|alt.badge.img+63
Can you elaborate a bit on what you're trying to do and what your source data looks like?
@add2116​ SpatialFilter might work. But elaborating on your question with a small sample dataset and the expected outcome as @Hans van der Maarel​ suggests might help us
