Having difficulty copying feature classes from arcsde to a file geodatabase.
  • May 23, 2022 4:19 PM UTC
  • 57 views
Used arcmap to import xml of data schema only from arcsde into a file geodatabase. Using esri geodatabase (ArcSDE Geodb) reader to esri geodatabase (file geodb). receiving error message:
An error occurred while attempting to open an insert cursor on the table 'Beacons'.
The error number from ArcObjects is: '-2147216556'.
The error message from ArcObjects is: {Objects in this class cannot be updated outside an edit session [Beacons]}
dustin
Forum|alt.badge.img+36
  • May 23, 2022 4:49 PM UTC
Under your writer parameters, change Transaction Type to 'Edit Session'.image
That worked. Thank you
