Handling line coordinate count
  • May 18, 2020 4:14 PM UTC
  • 5 replies
  • 128 views
I have autocad files i am pulling some polyline entities from. i am currently using the PointVertexReplacer to extract the coordinates of the polylines.
The problem i am having is that i began expecting 3 vertices; (a begin, a vertex, and an end). I encountered a line with 4 vertices. Previously i just iterated with AttributeFilter through 0,1,2 as these 3 vertices.
But because 1 line has 4 vertices the 3rd vertex is not the end. (it would be nice if there were a begin/end attribute that could be grabbed.)
I am trying to figure out how to filter these prior to this and can only come up with using the feature information but cannot expose this information. I can see the number of vertices value but it is not exposable. I assume i could do a count but it seems that would require quite a few more transformers.
Can anyone suggest how to accomplish this?
Best answer by jlbaker2779
Use a list element counter after the coordinate extractor. From there you can count the elements, use a ListIndexer of 0 to get the 1st coordinate and a ListIndexer of @value(_element_count)-1 to get the end coordinates.
This will work on any line regardless of the number of vertices.
Workbench example
3 vertices
4 vertices
  • May 18, 2020 4:32 PM UTC
Workbench example
3 vertices
4 vertices
erik_jan
Forum|alt.badge.img+26
  • May 18, 2020 4:35 PM UTC
Even simpler than using the element count is:
Use the CoordinateExtractor transformer and use index 0 for the start and index -1 for the en of the line.
FME has the capability to count backwards from the end using -1, -2 etc.
Hope this helps.
Hope this helps.
i edited my question. if they were lines i could do that. they are polylines so possibility of more that 2 vertices. I have done what you suggest but have index 0,1,2,3. in one case 3 is the end. in all other cases 2 is the end.
erik_jan
  • May 18, 2020 5:09 PM UTC
Try index -1.
It will always be the end.
And 0 will always be the start.
erik_jan
  • May 18, 2020 5:12 PM UTC
Hope this helps.
Like this:
Start:
End:
Make sure you set the Mode to Specify Coordinate.
