GLTF Writer doesn't write one single json file
  • January 31, 2017
  • 41 views
We use fme version 2017.0 (build 17143) and want to use the writer <glTF GL Transmission Format>.
Although we set the glTF File Format to <Single JSON file> we get 2 files, a gltf and a bin file.
What are we doing wrong?
Thank you.
itay
Forum|alt.badge.img+19
  • January 31, 2017
Could there be a separate writer parameter for that? Otherwise you could delete all bin files afterwards.
  • February 1, 2017
Thank you itay
Yes there are 3 writer parameter for the format, but the second one (Single JSON file) doesn't work for me, i get 2 files instead of one.
If i delete the bin file, i loose the geometry.
