GeoRSS Writer with multiple Links
Hello everybody!
I am very new to FME and I am using FME Professional 2012.
Successfully I generated some Atom-Feeds containing only one
Link-Element  using the GeoRSS Writer.
Subject of my Question is the generation of Atom-Feeds that
contain more the one Link-Element. I am not sure how to do
that using the GeoRSS Writer.
Thanks for your help!
fmelizard
Forum|alt.badge.img+22
Have you tried to fan out on the writer?
Itay
  • August 22, 2013
Hi Itay,
Thanks for the tip. The Option to fan out is disabled at my Featuretype.
emfme
fmelizard
Ok, the writer does have the option see: navigator>georss writer>parameters> advanced
Hope this helps,
Itay
  • August 22, 2013
Hi Itay,
your tip helped me to understand the difference between DataSet fan out and FeatureType fan out.
Regarding to the fan out page the option for DataSet fan out is enabled but the option for FeatureType fan out isn't. Sending more than one link attribute to the writer causes only the last one to be written to output file.
What I try to get is a feed that looks simplyfied like this:
<feed>  <title>...</title>
 <description>...</description>
 <id>...</id>
 <link>to ressource one</link>
 <link>to ressource two</link>
 <link>to ressource three</link>
 <entry>  ...  </entry>
 ... </feed>
What I got working was something simplyfied like this:
<feed> <title>...</title> <description>...</description>
<id>...</id>
<link>to ressource one</link> <entry>
</entry>
... </feed>
I know that there has to be a way using the more generic XML Writer to get my desired output. I thought thing would be easier with GeoRSS writer.
emfme
