geometrycoercer - OGC WKT type
  • Aug 14, 2014 12:21 PM UTC
  • 91 views
I discovered that the OGC WKT geometry obtained by the geometryCoercer is not a string object but a bytearray object
In a python caller:
wkt = feature.getAttribute('_geometry')
print type(wkt)
>>> <type 'bytearray'>
I think that's weird because WKT stands for Well Known Text and should be just string object. In my experience FME is the only tool where WKT geometry is not a string.  Why FME store WKT in a bytearray object?
Best answer by burton449
Alright the answer to convert WKT bytearray to string is the following:
in a python caller:
wkt = str(feature.getAttribute('_geometry').decode("ascii", "ignore"))
print type(wkt)
>>> <type 'str'>
  • Aug 14, 2014 1:40 PM UTC
in a python caller:
print type(wkt)
>>> <type 'str'>
  • Aug 14, 2014 2:21 PM UTC
here is another and easier way to do get the same thing:
wkt = feature.exportGeometryToOGCWKT()
This way you can also skip the GeometryExtractor before the PythonCaller.
David
  • Aug 14, 2014 2:27 PM UTC
Thats right, thank you for this shortcut.
