Geometry validator, failed objects
  • Mar 28, 2022 12:42 PM UTC
  • 122 views
fme_hans
Since we use FME 2021.2 I get many failed objects with the geometry validator, while with fme 2020 it did not yield any failed objects. Is there a substantial difference in the geometry validator between the 2020 and 2021 version?
@fme_hans​ OGC checks have been upgraded and are much stricter (no tolerance is used). But you should only see the changes if you upgrade the transformer.
fme_hans
  • Mar 29, 2022 7:59 AM UTC
The transformer is upgraded.
