geometry coercer question
  • June 3, 2015
  • 104 views
ingalla
Forum|alt.badge.img+10
I have managed to convert a polygon to a polyline using the Geometry Coercer which has produced a single line back to the start point.  As an addition i have added a chopper after the geometry coercer, which has chopped the line segment into the specified distance.
My question is this, if i have a square how do i get four line, and for an octogan how do i get eight lines etc.
I need to be able to create a new line when the angle changes but how do i acheive this.
Thanks
  • June 3, 2015
If you set 2 to the"Maximum Vertices" parameter of the Chopper ("By Vertex" mode), you can get four edge lines from a square, eight edge lines from an octagon.
In this usage, the GeometryCoercer is not essential. You can send the polygons to the Chopper directly.
Takashi
ingalla
  • June 3, 2015
Thanks for your help, thats ideal.
