Geometries dropping off on ESRI writer (update)
  • Dec 9, 2022 11:23 AM UTC
  • 55 views
Whenever I run data to the ESRI feature service writer (update), it updates the data with the relevant fields correctly but for some reason geometries are now not appearing when viewing the data in ARCGIS. Has this happened to anyone else before? Screenshot below
birgit
Forum|alt.badge.img+25
  • Dec 12, 2022 12:25 PM UTC
Maybe there is a problem with the extents of the ESRI service? can you see the geometry if you export the service data as FGDB, download it and look at it with either ArcGIS Pro or FME Inspector?
