GeoemtryReplacer - Invalid GeoJSON not rejected
  • Mar 22, 2023 11:05 AM UTC
  • 5 replies
  • 100 views
Forum|alt.badge.img+54
Not sure if this is a known issue or not, this is in FME 2020.2
GeoJSON processed by the GeometryReplacer results in a line with 0 coordinates, it is not rejected which is what i would expect to happen
e.g.
{"type":"LineString","coordinates":[[[0,0],[100,0]]]}
Processing this with the GeometryReplacer, results in this geometry
hkingsbury
Forum|alt.badge.img+73
  • Mar 22, 2023 7:28 PM UTC
Your coordinates array has one too many pairs of square brackets
{"type":"LineString","coordinates":[[0,0],[100,0]]}
  • Mar 22, 2023 7:31 PM UTC
Yes, that's the point. It's invalid geojson and I would expect it to be rejected by the geometry replacer but instead a line with zero coordinates is created, it is not rejected.
hkingsbury
  • Mar 22, 2023 7:41 PM UTC
Ah, I follow. Yes, as its specified as a line, I'd expect it to fail... as you can't have a line with 1 coordinate. It also "passes" if you just specify
    {"type":"LineString","coordinates":[[0,0]]}
It seems it might not be validating the geom type vs the output geom.
This is also happening in 2022.1
DanAtSafe
Forum|alt.badge.img+23
  • Mar 24, 2023 7:20 AM UTC
@ebygomm​ @hkingsbury​ FYI I've filed FMEENGINE-77079 about this issue.
  • Mar 24, 2023 9:44 AM UTC
Thanks, I wasn't 100% sure whether this would be expected behaviour or not.
