Generalize building and keep general shape?
  • Oct 19, 2021 7:47 AM UTC
  • 198 views
aron
Forum|alt.badge.img+16
I am looking for a method to remove the outcrops, circled in blue, from the building fotprints below. The generalization algorithms I have tried "soften" the polygons to much and make them look a bit organic. I would like to keep 90 degree corners as much as possible so that the viewer quickly can identity the shape as a building.
It might require a different process but I would also greatly appreciate suggestions on how to fill out the "jagged" corners circled in red.
Cheers!
Building2
Best answer by caracadrian
How about this:
Chop into lines, extend them, build topology then areas and keep the largest area for each feature.
You have to figure out a value for line extension that either generally applies to your data or as a derivate of the shape/number of vertices/segment length.Building generalization idea
caracadrian
Forum|alt.badge.img+23
  • Oct 20, 2021 6:08 AM UTC
Have you tried Deveau algorithm in Generalizer?
aron
  • Oct 20, 2021 7:22 AM UTC
Yes, Deveau does remove the outcrops, but does not retain she square shape of the building. Ie corners don't remain at 90 degrees. At least, I have not found a way to keep walls aligned.
caracadrian
  • Oct 20, 2021 8:03 AM UTC
How about this:
aron
  • Oct 20, 2021 8:35 AM UTC
How about this:
Thanks! That is a really good idea! Will try it out.
