FuzzyParallelLines
  • Feb 20, 2020 10:24 PM UTC
  • 116 views
Hi All,
I'm trying to select parallel lines from a shapefile using FuzzyParallelLineFinder. The output gives line_ID of the fuzzy parallel line for each feature with a given STDV value. What I need is how to select the features that are expected to be parallel from this output.
Any ideas?
Forum|alt.badge.img+54
  • Feb 21, 2020 7:42 AM UTC
The lower the STDV value the better the match. You will have to decide yourself at what value a line can be accepted to be parallel or not
