FME Server Could Not Connect to Core
  • Aug 16, 2017 6:17 AM UTC
  • 9 replies
  • 251 views
deanhowell
Forum|alt.badge.img+24
Our installation of FME Server has just stopped working.
All services are running but I have noticed in the Engine Logs that it is struggling to register engine.
2017-08-16 14:46:58| 0.3| 0.3|INFORM|FME(R) 2017.0.1.1 (20170512 - Build 17291 - WIN64)
2017-08-16 14:46:58| 0.3| 0.0|INFORM|FME_INSTANCE_NAME FMEQAS901_Engine1
2017-08-16 14:46:58| 0.3| 0.0|INFORM|Registering with FME Server on host 'localhost'...
2017-08-16 14:46:58| 0.3| 0.0|ERROR |FME Engine failed to register with FME Server 'localhost' on port 7070: Could not establish connection to host
Any advice would be welcomed.
Forum|alt.badge.img+63
deanhowell
  • Aug 16, 2017 7:39 AM UTC
Yes tried the troubleshooting guide but still nothing. I added local host entry, changed directly permissions, started the services (many times), tried accessing it from remote machine and much more :)
stalknecht
Forum|alt.badge.img+22
  • Aug 16, 2017 8:12 AM UTC
Can you check if the port is not blocked by a firewall.
In case the engine is on the same machine
open a cmd-prompt  on the server and type:
netstat -na | find "7070"
it should return:
  TCP    0.0.0.0:7070           0.0.0.0:0              LISTENING
  TCP    127.0.0.1:7070         127.0.0.1:61320        TIME_WAIT
deanhowell
  • Aug 16, 2017 10:27 PM UTC
it should return:
I get no result when running the netstat command. Does that mean I need to add something to our firewall settings?
stalknecht
  • Aug 17, 2017 4:38 AM UTC
Try turning it of to confirm it works without and immediately switch it on and add an exclusion to the firewall.
deanhowell
  • Aug 17, 2017 4:48 AM UTC
It turned out to be a database issue, where our Oracle database was locked.
caicedop
  • Jun 29, 2020 3:14 PM UTC
it should return:
Hi, when you say "on the server", do you refer to the web server where tomcat is running or Core/Engine server? Thanks.
daraghatsafe
Hi @caicedop, I believe in this case they are referring to a Core/Engine.
caicedop
  • Jul 3, 2020 1:01 PM UTC
In that case, the port 7070 is open and server is listening on that port. According to the logs the engine registers with no issue, but still getting "There was a problem communicating with the REST API" error.
