FME Reprojector vs Esri Reprojector
  • Apr 23, 2023 8:44 AM UTC
  • 5 replies
  • 238 views
checcosisani
Forum|alt.badge.img+14
HI
I use the Arcgis data Interoperabilty for the exercise present on the FME academy but I received an error related to the reprojection
so I suspect that the Arcgis data interoperability reprojection is a little bit different than FME
can you support please ?
thx
Francesco
daveatsafe
Forum|alt.badge.img+24
  • Apr 25, 2023 10:38 PM UTC
Hi @checcosisani​,
What are your settings in the Reprojector?
checcosisani
  • May 10, 2023 1:52 PM UTC
Hi @checcosisani​,
Sorry for late reply
I don't understandf exactly what you mean anyway I have this setting for reprojector
daveatsafe
  • May 10, 2023 3:05 PM UTC
In your original workspace, please right-click on the Reprojector transformer, then choose Properties. This will bring up the settings dialog for the transformer. Please post a screenshot of this dialog so we can see the settings, or attach a copy of your workspace to the reply.
checcosisani
  • May 10, 2023 4:59 PM UTC
Hi
in the original workspace I have reprojector with this settings
but I received an error so I tried to use the esri reprojector but I can't find the UTM83-10
imageso I dont understand if there are difference beetween the two reprojector
thx
Francesco
daveatsafe
  • May 10, 2023 6:41 PM UTC
The Esri reprojection engine requires that the datum transformation be explicitly set when changing between coordinate systems with different GCS's, but the Reprojector transformer does not allow choosing a transformation, so it fails when using the Esri engine.
If you want to use the Esri reprojection engine, I recommend using the EsriReprojector instead of changing the workspace Reprojection Engine settings.
The coordinate systems in the EsriReprojector use the Esri names instead of the FME names, so UTM83-10 would be NAD_1983_UTM_Zone_10N.
