FME on the Command Line - Linux (Ubuntu)
  • Jan 18, 2018 12:46 PM UTC
  • 148 views
Hi
I have recently installed FME Desktop 2017 on Ubuntu 16.04. I have been tasked with switching batch running of FME projects from windows (cmd) to ubuntu (bash) scripts.
On windows you can:
fme <workspacename>.fmw --<myparametername> <parametervalue>
But how to do the same thing in ubuntu?
FME is installed here > /opt/fme-desktop-2017
Thanks,
Mike
Best answer by gerhardatsafe
Hi @mike_gale ,
to run a file on Ubuntu you would use ./ in the command line. So to run the example you mentioned on Ubuntu you would navigate to /opt/fme-desktop-2017 and run this command:
./fme <workspacename>.fmw --<myparametername> <parametervalue>
For a quick syntax overview just run this:
./fme
Hope this helps!
Hi @mike_gale ,
./fme
Hope this helps!
  • Jan 19, 2018 8:59 AM UTC
Hi @GerhardAtSafe
I think that is what you call a full on Brain Fart moment :)
In my defense - I was up all night with a screaming 2 month old :)
Thanks for pointing it out!
