FME Migration from FTP to azure fileshare
  • Jan 5, 2021 12:49 PM UTC
  • 65 views
I have FME running as container, which uses FTP to connect and get a files from FTP location. we are migrating the FME to Azure Cloud and deploying container in VM. we would like to use azure file share instead of FTP. could anyone help us on this ?
  • Jan 5, 2021 12:51 PM UTC
Have you looked into using the AzureFileStorageConnector? It's fairly simple to use.
  • Jan 5, 2021 1:37 PM UTC
thanks for your response! i am very new to FME. i have gone through the document. what i understand is, we need to update workflow to use azure storage instead of ftp. correct me if i am wrong. is it possible to make change in one place which will be applied everywhere?
  • Jan 5, 2021 3:08 PM UTC
Your understanding is correct, you will need to update the workflow to use the Azure file storage.
Unfortunately I cannot say anything specific about what you need to change, as it depends on what you have implemented and how things have been configured. If necessary, I would recommend that you contact your nearest FME Partner to see if they are able to help you out with the specifics: https://www.safe.com/partners/partner-locator/
If you have specific questions, you can of course post them here.
