FME Form 2023 - Option Save As a .fme file is missing
  • Nov 23, 2023 5:10 PM UTC
  • 200 views
Hi all, we have just updated from FME Desktop 2021 to FME Form 2023.1.1.2. I want to create a mapping file .fme, but the option .fme is missing in the Save As- dropdown menu. Has this option been removed by Safe Software? Or has this functionality been transferred to another menu? Does a workaround exist? Thanks for your help!
Best answer by takashi
I agree with @mazi​ , mapping file is useful in some cases.
You can still save a workspace as a mapping file in the current version of FME Workbench.
Try changing the file extension from fmw to fme manually in the Save As dialog when you save the workspace.
DanAtSafe
Forum|alt.badge.img+23
  • Nov 23, 2023 5:18 PM UTC
Hi @mazi​ Yes, the option has been removed intentionally. Why do you want to save a workspace to a mapping file?
  • Nov 23, 2023 5:48 PM UTC
Thank you for the very quick answer :-)! The mapping file will be in use by other members of my department. We have used mapping files for this purpose since years. The users can easily access the routine and the quick translator by doubleclick and additionally I can prevent the users from editing, viewing and (accidentally) changing the workspace. I have already found the workaround by using a password for the workspace in the forum. Since we never encountered any problems with the mapping files, I thought it unlikely, that the option was removed.
  • Nov 23, 2023 8:17 PM UTC
  • Nov 23, 2023 8:58 PM UTC
Hi takashi, actually this was my first trial thinking, that the missing option is a bug, and hoping, that by choosing the .fme file extension I can trigger the creation of the mapping file. But doubleclicking the so created file resulted in opening the quick translator which instantly ran in an error because of the missing input file. (unfortunately the dialog where the user could provide the input file didn’t open). Probably I have to check the settings of the user parameter for the input file again. Do you know, when and why the option Save As .fme was removed from the dropdown menu? In the Safe Software’s documentation this option can still be found.
