FME Desktop 2020.0.0.0: What is the best practice to fix issues identified by “geometry validator” tool?
  • Dec 18, 2021 7:01 AM UTC
  • 600 views
jamal
Forum|alt.badge.img+5
For example, in the screenshot below, I got 1 failed, 4 invalid, 5 locations. What could be the best practice to fix them?
The data is attached
Clip_1364
hkingsbury
Forum|alt.badge.img+73
  • Dec 18, 2021 9:31 AM UTC
There is no hard and fast solution for geometry issues, it is all dependant on exaclty what the issue is. If you open the Feautre Information window
You'll then see a list of issues, some issues are subsets of others and may appear multiple times.
That one feature fails both OGC Simple and OGC Compliance because of a self intersection, and it also fails the seperate Self Intersects in 2D Testimagethe other output ports are detailed here: http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/geometryvalidator.htm
jamal
  • Dec 20, 2021 6:17 PM UTC
Thank you for the help.
How to show these errors in the entire drawings to better identify their locations in relative to the map?
Clip_1388
Clip_1389
Clip_1390
danminneyatsaf
Forum|alt.badge.img+13
Clip_1388
Clip_1389
Clip_1390
Hi @jamal​, you can either hold the ctrl key and select multiple green magnifying glasses to view the errors in the entire drawing. You can also just click on the top of the transformer itself, with nothing else selected in the workspace, and this should open all output ports in the visual preview window.
jamal
  • Dec 21, 2021 5:49 PM UTC
Very much appreciated for the help. It works fine.
Clip_1402
