FME crashes with JSONTemplater
  • Apr 3, 2020 9:15 AM UTC
  • 99 views
oscard
Forum|alt.badge.img+23
Good morning.
I've been facing all morning a FME crash that I do not understand. So far I have tested my workspace with two version: FME 2018.1 and FME 2020.0 both 32-bits. The process fails with both of them.
My source data is a Personal Database (MDB) without spatial information. In one table I have data about "group layers" and in other about "layers".
A group can contain layers and other groups. I must build a JSON with that info.
To build the JSON with the groups, I have used the following JSONTempalter:
ROOT contains:
    "version": "1",
    "tipo": "3",
    "servicios" : [
            fme:process-features("GRUPO")
GRUPO contains:
    "Nombre_ES": fme:get-attribute("NOMBRE_ES"),
    "Nombre_EN": fme:get-attribute("NOMBRE_EN"),
    "grupos" : [
        fme:process-features("SUBGRUPO", "PARENTID", fme:get-attribute("ID"))
And SUBGRUPO contains:
    "grupos" : [
That works fine and I get a JSON with the tree of groups and subgroups.
Now I want to add the layers in each group, so I have changed the templates as follows.
GRUPO:
    "grupos" : [
    "capas" : [
        fme:process-features("SUBCAPA", "PARENTID", fme:get-attribute("ID"))
SUBGRUPO:
    "grupos" : [
    "capas" : [
And I have created a new subtemplate called SUBCAPA:
    "Tipo" : fme:get-attribute("TIPO")
Whenever I run that, FME crashes with this error:
Even though that message appears, FME doesn't close. But the LOG doesn't have any kind of further information about the error. Here the last lines:
2020-04-03 11:04:49|   1.6|  0.0|STATS |Tester_2_PASSED Feature Counter -1 18(TeeFactory): Cloned 179 input feature(s) into 179 output feature(s)
2020-04-03 11:04:49|   1.6|  0.0|STATS |Tester_2_FAILED Feature Counter -1 2147680271(TeeFactory): Cloned 37 input feature(s) into 0 output feature(s)
2020-04-03 11:04:49|   1.6|  0.0|STATS |JSONTemplater_4_GRUPO_INPUT_FACTORY(TeeFactory): Cloned 15 input feature(s) into 15 output feature(s)
2020-04-03 11:04:49|   1.6|  0.0|STATS |JSONTemplater_4_SUBGRUPO_INPUT_FACTORY(TeeFactory): Cloned 56 input feature(s) into 56 output feature(s)
2020-04-03 11:04:49|   1.6|  0.0|STATS |JSONTemplater_4_SUBCAPA_INPUT_FACTORY(TeeFactory): Cloned 179 input feature(s) into 179 output feature(s)
2020-04-03 11:04:49|   1.6|  0.0|INFORM|JSONTemplater_4(XMLTemplaterFactory): All features received
Error running translation.
My workspace draft looks like this:
Does anyone know what could be the issue?
Thanks for any help provided!
Best answer by trentatsafe
Hello @oscard,
Would you mind submitting a support case, we can definitely take a look to see why this is crashing.
If you can submit a case here, please: https://www.safe.com/support/report-a-problem/
trentatsafe
Forum|alt.badge.img+7
  • Apr 3, 2020 6:19 PM UTC
Hello @oscard,
oscard
  • Apr 6, 2020 7:48 AM UTC
Hello @oscard,
Thanks!
I have just submitted the case: C153474
oscard
  • May 6, 2020 5:50 AM UTC
It seems the new version of FME solves this issue according to the Change Log:
------------------------------ FME 2020.0.1.1 b20222 20200416 ------------------------------
JSONTemplater/XMLTemplater: Fixed crashes in some recursive template situations [FMEENGINE-63979] C153474
I will test as soon as I can!
oscard
  • May 12, 2020 7:42 AM UTC
I have just tested the new version and this issue is fixed!
Thanks!
