FME as a client for a WebCoverageService (WCS)?
  • Mar 13, 2017 7:47 AM UTC
  • 149 views
femo
I can call a WCS by means of my browser, using a getcoverage request. The service returns
a geotiff, for example, that i can save to my disk.
It would be great to use FME instead. However, I only find WMS and WFS Reader.
Do you know a way to do it anyway, do I have to use the HTTPcaller?
Best wishes!
Best answer by david_r
Yes, I suspect you will have to use the HTTPCaller, I can't find any native support for WCS in FME.
It should be relatively straight-forward, however.
  • Mar 13, 2017 8:52 AM UTC
femo
  • Mar 13, 2017 11:57 AM UTC
Hi @david_r
Yes, the http caller works fine here. Attached you find a sample workbench.
Thanks a lot!
deanatsafe
  • Sep 27, 2018 6:49 PM UTC
We recently added support for OGC WCS reading in FME 2019 beta: safe.com/beta
vince_j
Forum|alt.badge.img+3
  • Jun 4, 2021 9:43 AM UTC
Hi @david_r
Thanks a lot!
Hi Femo, I came across this thread facing a similar problem with FME 2018, the version used by my client. The http caller returns an extensive code in the _response_body field instead of the raster file with cell values. I noticed that you mentioned that you had attached a sample workbench to your post. I can't seem to find that workbench. Do you think you still have that workbench, after 4 years? Or do you know of a way to correctly parse a WCS URL in an http caller so that it returns the actual raster file? Sincerely, Vince
