FME 2018 bug annotation
  • Mar 19, 2018 10:08 AM UTC
  • 11 replies
  • 95 views
When I create a tunnel from a long connection line than the first annatation is the same length as the connection line.
Best answer by andreaatsafe
Hi @bob123, @danilo_fme, @redgeographics and @takashi
Update: The annotation length when creating a tunnel problem has now been resolved and is available in the latest FME 2018 release found here.
Forum|alt.badge.img+63
You're right, I'm seeing it too @NatalieAtSafe could you pass this on to support please? I'm using build 18284 on Mac
  • Mar 19, 2018 11:41 AM UTC
I too came across the same symptom on build 18284, Windows.
danilo_fme
Forum|alt.badge.img+58
  • Mar 19, 2018 3:06 PM UTC
@bob123
I did have the same situation in my build 18284, Windows ( same @takashi)
Thanks,
Danilo
andreaatsafe
Forum|alt.badge.img+17
Hi @bob123 , @danilo_fme, @redgeographics and @takashi,
Thank you for reporting the issue!
I've filed a problem report (PR#82794) for this and will update you here when it has been resolved.
danilo_fme
  • Mar 20, 2018 11:46 AM UTC
Thanks @AndreaAtSafe
  • Apr 3, 2018 10:00 AM UTC
2018-04-03-115932.pdf2018.0 It is better but not good
andreaatsafe
andreaatsafe
  • Apr 3, 2018 6:26 PM UTC
andreaatsafe
Hi @bob123,
Thanks for letting us know about this other problem. It looks like the tunnel vertexes are not staying inside the bookmark box. I've let our team know (PR#82979) and will update here when it has been resolved!
danilo_fme
  • Apr 3, 2018 9:36 PM UTC
to reply us if this news :)
andreaatsafe
Hi @bob123,
I'm please to let you know the problem with creating a tunnel within a bookmark has been resolved! The fix is available in the latest FME 2018.1 beta (build 18449 or higher) release found here.
