FME 2017.1 Miscellaneous
  • Sep 21, 2017 7:41 AM UTC
  • 12 replies
  • 70 views
I'm now working with localization of FME Descktop 2017.1. It's also a good opportunity to take a closer look at what's new. I would post something I noticed through the job.
FME 2017.1 build 17539
1. ListBuilder
The "Input Ordered" parameter seems to be shown at a wrong location.
2. NeighborFinder It's great that the new parameter "Take Measure/Z From Candidate" has been added. However, I'm not sure if it's reasonable that "Yes" is set to the parameter by default. How do you think about this?
possibly to be continued...
Hi @takashi
re ListBuilder: you would prefer Input Ordered parameter to be right after Group By, am I correct? This would be the same dialog structure as e.g. in FeatureMerger.
  • Sep 21, 2017 6:46 PM UTC
Hi @takashi
Yes.As far as I know, in other transformers that have the Input Ordered parameter (including the ListBuilder itself in FME 2017.0 and eralier), the parameter is generally within the parameters group "Transformer". I think it's better to arrange the parameter close to the Group By parameter.
Agree. I have filed a PR asking to place the parameter below Group By.
fmelizard
Forum|alt.badge.img+22
  • Sep 22, 2017 7:04 PM UTC
Good catch re: the ListBuilder. We'll address.
But the NeighbourFinder I don't know what the best default is. @takashi -- do you think No is better. Is there a downside to transferring elevation?
  • Sep 22, 2017 9:51 PM UTC
I'm afraid there could be scenarios where the user doesn't expect the original z-coordinates of base 3D points will be changed. If they didn't set 'No' to the parameter, z of points would be changed unexpectedly. In a case, the 3D point would be forced into 2D points if the closest candidate line was 2D.
  • Sep 22, 2017 9:53 PM UTC
Hi @takashi
@LenaAtSafe, thanks for filing the PR.
  • Sep 23, 2017 12:31 PM UTC
Regarding the NeighborFinder parameters, I have another interesting discovery.
The help documentation says:
"A value must be specified for at least one of the Number of Neighbors to Find and Maximum Distance parameters."
"Note: To get the distance from a given Base to all Candidate features, use a very large number for this parameter and specify a Close Candidate List Name."
However, in fact, you can leave both the Number of Neighbors to Find and Maximum Distance parameters blank to get the distance from a given Base to all Candidate features.
I think the help should be updated if it's an intentional behavior.
Hi @takashi,
Your suggestions and corrections have implemented in FME 2017 build 17645 and FME 2018 beta build 18176. Thank you for helping us make FME even better!
Hi @takashi
I have PRed this as well. I believe the leaving blank behaviour is by design. If this indeed is the case, we will update the transformer description. Thank you for catching this mismatch.
  • Sep 29, 2017 11:54 PM UTC
Hi @takashi
Hi @LenaAtSafe, thanks for filing that. In addition, this setting is also available to find all Candidates for every Base.
  • Number of Neighbors to Find: 0
  • Maximum Distance: <not set>
Let me add this to the PR.
fmelizard
  • Jan 29, 2018 7:30 PM UTC
Hi @takashi The doc re the NeighborFinder has been updated in FME 2018.0
