Flatten part of a mesh
  • Jul 9, 2019 4:19 PM UTC
  • 106 views
itsmatt
Forum|alt.badge.img+48
Hi All,
I'm wondering if there is an efficient way to flatten part of a mesh. I have a large mesh and in part of the mesh I simply want to set the z value to say 0.
I don't want to recalculate the triangles, just offset the effected vertices. The only way I can see to do this is to break the mesh down into it's vertices which seems super inefficient.
open to any ideas
nielsgerrits
Forum|alt.badge.img+67
Like the SurfaceFootprintReplacer?
itsmatt
  • Jul 12, 2019 8:15 AM UTC
Hmm, not quite what I need, I don't think it works for what I want. More similar to the SurfaceDraper, where the surface is just a polygon at a certain height. I tried the SurfaceDraper but it never really worked in the way that I expected it to. In my case the Mesh (which I want to drape) is much larger than then polygon which I'm draping it over. It's almost like I want the opposite of the SurfaceDraper - More like a SurafceExtruder. Ahh well. I manage to get the result I wanted but it just took a long time.
Thanks for the suggestion @nielsgerrits!
daveatsafe
Forum|alt.badge.img+24
  • Jul 16, 2019 4:45 PM UTC
Hi @virtualcitymatt,
If you don't mind dipping into the Python API, you can use the FMEMesh methods to extract and modify the mesh vertex elevations. A little more complex, but likely quite a bit faster.
itsmatt
  • Jul 17, 2019 8:19 AM UTC
Thanks for the tip Dave. I will investigate this as an option. Want to practice my python anyway :D
