Finding entries in a spreadsheet where a value has increased
  • Oct 27, 2020 2:23 PM UTC
  • 99 views
joe.fme
Hi FME Community,
I've been sent a spreadsheet with a series of rent entries. The name of the property, the dates and rent are the fields which are important.
For each entry, which is a single line per rent payment, there may be an increase in the amount. This can be after 1 line, or 20. Basically, I need to only keep the entries which show an increase in rent amounts.
Trying to find these entries and automate them seemed simple at first - but has stumped me.
If anyone has any ideas, I'll be very grateful.
Thank you
Best answer by fhilding
Hi Joe! I attached a workspace that uses attribute creator with adjacent features to solve how I interpreted your question. It looks for the previous row (after sorting the initial input), checks that it's the same property ID(or name, in your case) and if the rent_paid is greater than the previous months rent_paid. If so, it sents rent_increased to 1, otherwise it leaves it at 0. It's important to check for the property ID/names being the same too, otherwise you'll get edge effects when the property changes.
If you need to restore the original order, a counter before any of this stuff is a good idea. Let me know if I didn't get any aspect of your original question / input data correct, because there's more fun to be had with this stuff (VariableSetter / VariableRetriever especially!) : )
I couldn't upload the data in the same post, so... here's the data my example uses!
  • Oct 27, 2020 3:06 PM UTC
joe.fme
  • Oct 27, 2020 3:13 PM UTC
Hi fhilding, thank you so much! I was going down the adjacent feature route and you....well you just hit the nail on the head.
You absolute star, thank you
  • Oct 27, 2020 3:30 PM UTC
All good! Happy change-hunting :)
