Finding closest neighbor based on angle
  • January 9, 2014
  • 59 views
Can the NeighborFinder transformer be set to only link features that are of a certain angle range from each other?
For example, I have two parallel lines running in the east/west direction that represent the edge of the pavement of a road. If there is a point feature somewhere between those lines, can I find it's nearest neighbor line in the North direction (even though the southern line may be closer)?.
Text Diagram:
________________________________________________________ North Line
                                                    .    Point Feature
________________________________________________________ South Line
Is there any way to link that point to the North Line?
  • January 10, 2014
One possible solution is: 1) Append unique identifier attribute to every point, e.g. "_point_id".
2) Send the points to BASE, the lines to CANDIDATE of the NeighborFinder. And specify "Close Candidate List Name" parameter, e.g. "_close".
3) Apply a ListExploder to MATCHED points. After exploding by "_close{}", every point will have "angle" and "distance" attributes which are the information of location on a line within the specified distance.
4) Filter the points by the specified angle range. Assume each point has min / max of the angle range.
5) Sort them by "distance"  ascending.
6) Use a DuplicateRemover grouping by "_point_id" to select points having minimum distance in the same "_point_id"; i.e. each first point in the same "_point_id" group.
Takashi
