Find overlapping segments of two MultiCurves
  • Apr 13, 2021 3:19 PM UTC
  • 79 views
mickael
Hello,
I have two geojson files, available [here] (until the 21/04/2021). Each one contains a MultiLineString feature, converted to IFMEMultiCurves with FME. I would like to be able to detect any overlapping segment, with some tolerance, no matter their directions, and set a property to any overlapping (or "close-enough") segment from one dataset with any segment from the other dataset.
I have tried various transfomers, but I am not able to detect overlapping segments, nor to break my datasets into segments ...
Any advice about how to do this ?
Thanks in advance :)
Best answer by mickael
Thanks @Mark Stoakes​ I eventually figured this out, using :
Chopper (Mode "By Vertex + Maximum Segments = 2) > CommonSegmentFinder > LineCombiner > Attribute Manager
I have not tried the Matcher for this
@mickael​ Thanks very much for including the sample dataset.
I think if you use Chopper to break all your lines into two point line segments, the Matcher will pickup the duplicates.
mickael
  • Apr 15, 2021 3:03 PM UTC
