find and filter maximum z value in duplicate points
  • February 18, 2014
  • 25 views
venu
Forum|alt.badge.img+5
I have duplicated points in that I need to find and filter maximum z value points.
is there any solution?
Thanks in advance
Venu
Best answer by takashi
Hi Venu,
One possible way is:
1) CoordinateExtractor
X Attribute: _x
Y Attribute: _y
Z Attribute: _z
2) Sorter
Sorting by _z, Numeric, Descending
3) DuplicateRemover
Key Attributes: _x  _y
Use points coming from Unique port of the DuplicateRemover.
If there could be slight error on (x, y), consider using the AttributeRounder to adjust the digit number of decimal fraction before the DuplicateRemover.
Takashi
  • February 18, 2014
Hi Venu,
X Attribute: _x
Y Attribute: _y
Z Attribute: _z
2) Sorter
3) DuplicateRemover
Takashi
