FeatureWriter Updating Esri FileGeoGDB (ArcObjects)
  • Mar 27, 2020 8:10 PM UTC
  • 85 views
mhab
Forum|alt.badge.img+10
I try to update FeatureClasses in an Esri FileGeoDB.
I use FeatureWriter with fme_db_operation=update and dynamic schema setting. FeatureClasses have NOT NULL attribute constraints.
Problem: How do I control which attributes are updated ?
I have the impression, that I cannot update only some attributes without specifying all attributes of the FeatureClass/Table. If I do not supply an attribute it will be set to NULL.
Is that really so ? Is there a way to leave attributes unchanged, while others are updated ?
That's what I am used to from SQL ...
Thanks
Michael
@mhab To update only some fields in a database follow the instructions in the article Updating Individual Fields of a Record
mhab
  • Mar 28, 2020 4:07 PM UTC
@markatsafe Thanks for the hint.
I just found that one too and learned my problems must have other reasons.
Non-existing attributes will not change the database. Happy to know that now.
