Features are missed when translated
  • August 5, 2014
  • 51 views
I have a .gpx file and I want to convert it to Esri Geodatabase feature class, I created a workbench (shown in the screenshot) to handle the conversion. The gpx file contains 3 features: Way points, Track, Track Points, and I can inspect each feature alone in the inspector, but when coming to translation only the Way Points are constructed. This is discussed below in the screenshots.
Best Regards,
Hani
1- Input .gpx file in the inspector
2- The workbench
3- Inspecting each feature class after splitting them using testers
4- The Track and Track Points are not translated!
gio
Forum|alt.badge.img+15
  • August 6, 2014
Hi Hani,
You are writing to a file_gdb.
Yuo have set it to accept points. So it stops when you feed it lines (your track).
If you remove the linewriting connection, your trackpoints will be written.
gio
  • August 6, 2014
btw..this is probably reported in your logfile. Check your log.
  • August 11, 2014
Hello Gio,
Thank you very much, that’s right!
Usually, when I create a writer I use a static schema, but this time I used a dynamic schema. The difference here is when using a static schema, it asks me to define the attributes type, but with dynamic schema, I can’t define the attributes type. I can’t figure out why it behaves like this, do you have an idea why it behaves like this?
This is shown with screenshots:
1-
2-
3-
4-
5-
