FeatureReader NOT showing output ports.
  • Mar 28, 2023 1:25 PM UTC
  • 7 replies
  • 258 views
jrlalessi
Forum|alt.badge.img+7
I am using the FeatureReader to connect to an ESRI SDE. I have specified the features to read, and selected Output Ports: One per feature, BUT out put ports are not being created for the features I specified. In only the default ports are available.
I am having a similar issue with another FeatureReader that is pointed to a FGDB. I had to change the directory path for the FGDB and now all of the output ports are gone. I reset all of the "Features to Read" but like the above, I am not getting out put ports for the features I have specified.
image.pngIn the above there are no Output ports for the features specified.imagein the above only some of the Output ports for the features specified are available.
nielsgerrits
Forum|alt.badge.img+67
What version FME do you use? I can't reproduce this behavior in 2021.2.6. Just checked as I'm currently working on a workspace reading a FeatureClass from SDE.
jrlalessi
  • Mar 28, 2023 1:51 PM UTC
I'm using 2020.1.0. , Build 20596.
Ive been poking around and even when I specify the features to read the port is not made available.
It could be that the sample data Im using is missing the features, but I would expect the output port to remain in place.
nielsgerrits
Maybe it has to do with special characters or a very long string? I'm guessing here, you probably better submit a case at Safe Software.
ingalla
Forum|alt.badge.img+10
  • Mar 28, 2023 2:24 PM UTC
I connect to SDE Feature classes all the time and have never seen this behaviour, I can only suggest issues with the naming of the feature classes....I don't think it would make a difference but noticed you have the spatial filter set to intersects, but could not see a second input...
ingalla
  • Mar 28, 2023 2:29 PM UTC
Just a thought, but you do have the ESRI edition of FME as that is needed to read the SDE??
jrlalessi
  • Mar 28, 2023 2:53 PM UTC
Do you mean the Data Interoperability extension? Yes I do.
Currently the reader for the workbench is pointed to FGDB(1) and the feature reader is pointed to SDE. If that helps.
I have also NEVER seen this before and pretty much only work in SDE/FGDB.
hkingsbury
Forum|alt.badge.img+73
  • Mar 29, 2023 1:04 AM UTC
Just checking, that under Parameters of the SDE FeatureReader, you have set an SDE connection file?
