FeatureReader, adding multiple files
  • Jan 24, 2013 11:00 AM UTC
  • 0 replies
  • 31 views
Forum|alt.badge.img+54
I have an issue with the FeatureReader. Within the FeatureReader Parameter dialogue I'm adding multiple Mapinfo files, and choosing to select all FeatureTypes on the next screen. When I run the workspace only one file is read and when I return to the FeatureReader Parameters it only lists the parent directory of one file, rather than the individual files selected .
If I add a directory and then just choose some FeatureTypes the reader works as expected and I get multiple outputs.
If I add multiple directories then only files from one directory are read.
Am I trying to do something that's not possible, or am I missing a setting or similar somewhere?
( FME 2012 (20120115 -- Build 122212 - WIN32) )
