FeatureMerger UsedSupplier
  • Jul 21, 2020 10:59 AM UTC
  • 5 replies
  • 45 views
sunsilk11
Hi I am using FeatureMerger to merge attributes and geometry as follows
Table1:
ID1 Value1
ID1 Value2
ID1 Value3
Table2:
ID1: Code1
ID2: Code2
ID3:Code3
I would like to end up with 9 records in the output
Expected result:
ID1 Value1 Code1
ID1 Value1 Code2
ID2 Value1 Code3
ID1 Value2 Code1
ID1 Value2 Code2
ID2 Value2 Code3
ID1 Value3 Code1
ID1 Value3 Code2
ID2 Value3 Code3
I have tried various options in FeatureMerger, but I am still missing records in the output
This seems to be in the Used Supplier port.
Any suggestions ?
Forum|alt.badge.img+54
  • Jul 21, 2020 11:18 AM UTC
Which attribute are you merging on?
sunsilk11
  • Jul 21, 2020 11:57 AM UTC
Joining on ID
  • Jul 21, 2020 12:02 PM UTC
Joining on ID
I don't see how you would get the 9 records you list as output, where would this value come from
ID2 Value1 Code3
sunsilk11
  • Jul 21, 2020 1:09 PM UTC
ID2 Value1 Code3
Sorry you are right. Typo
Table2 is rather:
ID1: Code1
ID1: Code2
ID1:Code3
ID1 Value1 Code1
ID1 Value1 Code2
ID1 Value1 Code3
ID1 Value2 Code1
ID1 Value2 Code2
ID1 Value2 Code3
ID1 Value3 Code1
ID1 Value3 Code2
ID1 Value3 Code3
  • Jul 21, 2020 1:22 PM UTC
If only Table1 contains geometry you can use a FeatureJoiner with a Full Join
